Sets the value for Neighbor Discovery Protocol (NDP) retransmit time
| retransmit-time | Specifies setting the retransmit time. |
| retransmit_time | Sets the retransmit time value (range is 1–4,294,967 seconds or 1– 4,294,967,295 milliseconds). The default is 1 second. |
| milliseconds | When setting the retransmit time value, specifies milliseconds as the time unit (range is 1–4,294,967,295). |
| seconds | When setting the retransmit time value, specifies seconds (range is 1–4,294,967) as the time unit (default). |
The default setting for the retransmit time is 1 second. The default unit of measure is seconds.
configure neighbor-discovery cache retransmit-time 500000 seconds
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
